One night, the car was fine. The next morning, it wouldn't start. The starter works. The battery's brand new. The AAA road assistance guy confirmed the battery's good, and he thought fuel pump. Car's a 1996 Grand Voyager SE, 3.3L.
Apparently, if the cause is not the fuel pump, then it's electrical or in the PCM, things I would enjoy learning about, hopefully at leisure. :angry: It's not the fuel pump.
One week before the no start problem, the gas gauge seemed to hit empty even more prematurely than before. As it turns out, at the moment when the car wouldn't start, and the needle was totally on empty, there was four gallons in the tank, that's 20 percent full.
On these cars, when you turn the ignition to ON, not RUN, this activates the fuel pump relay for several seconds (some say 2 seconds, others seem to be saying 10 seconds). The ASD relay does not come into play until the key is turned to RUN.
I mounted a fuel pressure gauge and cycled between ON and OFF. Needle didn't budge: more evidence it could be the fuel pump.
I just installed a new pump, aftermarket (Carter). Gauge needle still doesn't budge. I don't hear the new pump whirring, but could that be because it whirrs too softly to hear from the driver's seat?
I've put over 2,000 miles on in two months, and up to now there were no electrical type problems like driving over a bump failures, intermittent failures. With the key in ON position, the dashboard lights up.
The fuses for the fuel pump relay and ASD relay are both 20 amp. I checked all the 20 amp fuses that are in the PDC (power distribution center, next to the battery). I bought electrical parts to fashion jumper wires, but I haven't fashioned any and I haven't tested the relays yet.
They say check for spark. First, I put in new plugs and wires, the front plugs a month before this trouble, the rear plugs seven days before it (oh, and when I put the plenum back on, I was meticulous about reattaching the wire harness that screws into its back side). Second, I'm game to perform the starting fluid test, but where do you spray the stuff? On cars since the 90's the plenum covers up intake manifold. Do you take off the resonator and spray into the throttle body? Third, how do you test the ignition system when you can't get the engine to start? Will ohmmeter testing of the coil tower be enough?
Spec fuel pressure is 49 psi. Two months ago, I replaced the fuel filter (without taking off the fuel tank, I just lowered it a little). I forget how many ignition cycles it took to get the needle moving, but seven is surely enough.
What should I try next?
