1 - 1 of 1 Posts
Hello everyone I’ve changed out both the pump and sensor. Still can’t clear this code. PO6DD. What do I need to do to clear this code. The pump came from rockauto. And the sensor is from advanced. Someone said it needs a own pump. Could this be right. Uggg. The code says permanent. I’m draining the system today with a capacitor. Hopefully it clears the code. I also have a low voltage code
PO562. Not really sure about this one either. It’s a 2012. 3.6.
thanks for your help. In advance.
jimmy
1 - 1 of 1 Posts
