1 - 4 of 4 Posts
Hi,
My check engine light won't shut off. I changed the EGR valve, O2 sensor upstream and downstream, spark plugs, spark plug wires - still won't shut off. Any suggestions because it won't pass emissions.
Thanks!
Year - Make - Model - Engine - Mileage please
As atoman noted, pull the OBD codes so there is a starting point for diagnosing.
Were OEM/NTK O2 sensors used? Denso has been known to work but no Bosch (hit or miss proposition).
1 - 4 of 4 Posts
