1 - 3 of 3 Posts
Hi. I just changed the aux battery in my 2019 Pacifica, and now I'm having a problem with the climate control. It can no longer be set to "Auto", and can only toggle between "Hi" and "Lo" temperature. The controls for the heated seats are also no longer visible. Is there something that needs to be reset in Uconnect? Thanks.
Reboot the radio/Uconnect system by putting the car in ON (no need to step on brake pedal) and then press the volume knob for about 10-15sec and let it reboot until your Uconnect display stabilizes. After this you should have your heated seats, heated steering control back in the Climate /Comfort screen
1 - 3 of 3 Posts
