1 - 5 of 5 Posts
Hi all, I have a 1993 Grand Caravan, 3.0L. Jerking and stuttering under load, code indicates cam position sensor, which makes sense.
Problem is, one reference I use indicates the 3.0L Grand Caravan does not have the sensor, while the 3.0L Caravan does have the sensor. Hmm. Further, I cannot find the location of the sensor in all the likely places on this engine.
Seems impossible this engine would not have the sensor. Can someone point me to its location?
Thanks in advance!
It's built into the distributor. It is a magnetic pick-up coil. Wires may have gotten damaged over the years, so check continuity while flexing the wires.
1 - 5 of 5 Posts
