1 - 12 of 12 Posts
I noticed a coolant leak coming from the engine on the opposite side of the coolant reservoir (driver side).
This metal component has been corroded to the point of leaking and breaking:
Rusted component; the back side is flat and fits in the orifice in the photo below
Here is a photo of the engine where the component broke:
My main ask is what is this component?
I cannot find a similarly-shaped component (with a flat side and only one tube) in the 'Coolant System' within the RockAuto shop here:
Thanks in advance for your consideration.
You can't get a new part on Rock Auto. This is a heater supply pipe. It takes the hot coolant from the top of the engine and connects it to the heater core intake hose. Probably just need to get a good used one from a junkyard. 3rd gen van I think also uses this same pipe.
that part is really corroded. i'm guessin its aluminum ? i looked briefly on rock auto and i dont see one either. did u try looking at local junk yards then. now i have to look at my 3.3 and see its condition ? you might be able to get one off a 3.3 later years ? if you cant find one let me know ? i might be out at the junkyard later this week ? u pay the shipping and part ? thanks
doo doo da doo ! so what s doin with dis ?
1 - 12 of 12 Posts
