Coolant leak at back of water pump housing
4 reading
459 views 26 replies 6 participants last post by  FabricGATOR
#1 ·
I hope someone else has had this issue and can help. 2005 Town & Country Limited 3.8L with ~188k miles. I have been losing coolant for awhile now, but I couldn't find the source. I don't notice it with the van running, but when I turn the van off after it gets up to temperature, you can see a steady drip of coolant on the passenger side. I raised the van on jack stands and removed the splash shield so I could get a better look. There is a pin hole leak in a 90 degree rubber boot on the back side of the water pump housing. Not even sure what this rubber boot is or what the part number might be. Rear heater hose, maybe? Any help would be greatly appreciated.
#2 ·
I found the leaking part and now I know why it didn't show up in any parts diagrams lol. It is a heater bypass cap. We bought the car when we still lived in Florida so a previous owner must have bypassed the rear heater or something. Should be an easy fix and hopefully I'll get another 130k miles before it gives me problems again!
#4 · (Edited)
Yep, does appear to be the heater core return hose/pipe assembly that has been disconnected/removed and capped off...
Normally a short hose there going over to a pipe bolted to the back side of the motor with that pipe ultimately heading upward behind the driver side of the motor where there is another short hose that, presumalby, attached to heater core return piping. I say "presumably" because I've never actually paid any close attention to where it connects on the upper end!
Suspect you have another cap up there somewhere...
#6 ·
The strange thing is that the heater works fantastic in the van and it does have the normal heater tubes going into the firewall. Just wondering if this is maybe a normal condition for vans with the dual HVAC system. Thankfully I got it fixed and we'll see how long it lasts. The part was $3 so I guess that's better than a blown head gasket lol
#11 ·
The clamp is most likely fine if it felt tight going on. They don't really wear out. Another fix would be to get a small piece of fuel line that size, clamp it on, stick a bolt tightly into the open end and clamp that with a screw clamp. I've done that many times over the years for various issues and never had a problem. I would trust that more than a cap.
#12 ·
Good advice! Thank you. If it gives me any more trouble, I will try this. The clamp did feel tight going on, but I didn't like that I could spin the new cap with my hand after putting the clamp on. I might swap out the pinch clamp with a screw type host clamp so I can tighten it more. I'm hesitant to mess with it though because if the cap comes off when I am removing the clamp, I will be taking another bath in coolant.
#13 ·
Yeah, that's not very confidence inspiring. I prefer screw clamps for most applications. Some people say spring clamps are better because they expand and contract but I like be in control of how tight they are. Most problems from screw clamps are because people over torque them and cut into the hose.
If I were to swap the clamp I would put my finger on the end of the cap and slide the clamp as far off as I can. Then pinch the hose from the bottom, where the clamp was, and slide it off the rest of the way.
#14 ·
For your application, these are junk, worm gear screw clamps.
Ideally you want some like this as you want control. (y)
The t-screw holds better with equal force all around vs worm gear tight on one side only by the screw.
This is what you will see on performance vehicles too.
owns 2006 DODGE GRAND CARAVAN SXE
#20 ·
He's referring to the hose going from the radiator neck, just under the radiator cap, over to the coolant overflow reservoir at the front driver's side.
In other words, he's saying that if you keep the system closed up everywhere other than the cap you are going to replace then the lack of venting will assist in minimizing how quickly coolant flows out that return nipple you are working on as there will be somewhat of a vacuum fighting the flow.
Of course, this assumes that your radiator cap itself is good and sealing properly... and that there are no other leaks elsewhere in the system!
#25 ·
Any dirty old container or even a stout cardboard box... the trick to clean and reusable fluid is a clean new trash bag.
Another trick for working on fluid with our hands is to tie a rag around your wrist to stop the fluid from running along your arm and into your armpit, beyond
Reactions: Derrick1971
