I think it was '14 where the bigger brakes became standard as opposed to requiring the towing package.
Hi. Your advice makes solid sensé. I bought, one month go, a 2016 t&c with 100 kms, or 60 k miles. One owner since new, not much for service records, or CARFAX. What would transmission service be? Last time I changed trans fluide, (2007 caravan) I got a chudder out of the deal. Scared to go near à transmission, but I guess it should be looked at soon. Same for cooling ? Is the econ mode à bad thing ? My major problem is... New tires, shimmy after 3 balancing jobs. Going to service brakes next. Suggestions welcomed !2014-15+ will have the better brake package.
It will have the updated oil cooler design that is less prone to failure.
It will have the updated rocker design that is less prone to failure.
Price has a lot more factors to it than just year/miles.
What package the van is.
Any accidents.
Maintenance records.
Etc.
All affect price.
I understand cost is a concern, but I would be more concerned with the PO of the van.
My rule of thumb on any of these vans:
1. Buy it under 30k miles so the PO hasn't had enough time to do any irreversible damage.
2. Buy it with full maintenance records so I know it's been well cared for.
3. Buy it so dirt cheap I can afford to go through and fix everything the PO wrecked.
The only given with these vans is that they haven't been taken proper care of, unless there are records to prove otherwise.
You want to see oil changes every 4-5k miles. Transmission service every 30-50k. No use of ECON mode. Cooling system service w/thermostat every 60-80k. Coils/plugs well under 100k. If these things haven't been done, walk away.
1. If you got shudder after doing a trans service, it's likely you either used the wrong fluid, filled to the wrong level, or your transmission was already on it's way out. The transmission fluid/filter should be changed every 60k miles MAX. It uses only ATF+4 fluid.Hi. Your advice makes solid sensé. I bought, one month go, a 2016 t&c with 100 kms, or 60 k miles. One owner since new, not much for service records, or CARFAX. What would transmission service be? Last time I changed trans fluide, (2007 caravan) I got a chudder out of the deal. Scared to go near à transmission, but I guess it should be looked at soon. Same for cooling ? Is the econ mode à bad thing ? My major problem is... New tires, shimmy after 3 balancing jobs. Going to service brakes next. Suggestions welcomed !
