It's an electro-magnet, correct? Do you have a photo of one? I know that you are looking for new parts, but I might have a used one from the 93 Chrysler I scrapped out in 2010. The part I'm thinking of is a white plastic deal with a stem about 2 1/2" long.Do these still exist anywhere as new replacements parts? I can't find any. My driver’s doors unlock is getting weak. Only actuator available I can find is the sliding door.
I have the same issue with the driver door not unlocking while the rest do just fine. I haven't attempted to fix the issue yet, I just unlock it with a key....I've gotten used to that lolNow I’m curious if this is a common fail item. Considering how universal this part probably is and the vast number of compatible vehicles produced.
Has anybody else experienced weak or non-working door locks? My passenger side works perfect, but the driver side is on its last leg and soon to be in-op with the coming summer heat.
The vehicle from which I took the part above did NOT have the remote lock/unlock feature, only the key operated lock/unlock. So maybe the photo I posted is not the correct part, unless on yours (Sanchez) the interior door lock (toggle) switch also no longer works. At least I suspect that's what this actuator did on my 93. I'd have to look at the door lock assembly again to be able to say if turning the key in the lock physically disengaged the lock, or if it ran the lock mechanism electrically. (I dismantled this car over 10 years ago, so I do not remember.)I have the same issue with the driver door not unlocking while the rest do just fine. I haven't attempted to fix the issue yet, I just unlock it with a key....I've gotten used to that lol
That's not a door lock actuator. It is a switch for the security alarm system. Older Chrysler vehicles used a separate actuator. At some point Chrysler began making the actuator integral with the latch. I can't recall what type a 2nd gen van would have. However, if it still used a separate type of actuator it would be much more substantial in size than the switch that you show.Here is a picture of the part I think you are talking about.
OK. Makes sense. I didn't catch on right away that the question had to do with a REMOTE lock/unlock control. Our 93 T & C was pretty much top of the line in terms of all of the options I heard of as offered then, but it did not have remotes, just the simple keys.That's not a door lock actuator. It is a switch for the security alarm system. Older Chrysler vehicles used a separate actuator. At some point Chrysler began making the actuator integral with the latch. I can't recall what type a 2nd gen van would have. However, if it still used a separate type of actuator it would be much more substantial in size than the switch that you show.
