Hello All,
We have a 2015 Dodge Grand Caravan with 58K miles and a 3.6L engine. Had our oil changed at Take 5 last week and the CEL came on after the third engine start and dist of about 8 miles after the oil change. I have returned to Take 5 twice and they have visually checked to ensure that the components removed during the oil change look okay. First time they found 1 of the 3 clips on the air handler case covering the air filter had not been secured and the second time, they found the air filter was not firmly and squarely seating in the air handler case. But the P06DD code keeps coming back after starting the car a few times after the reset.
I was sitting in the car when they changed the oil and was flabbergasted with all the parts they removed to perform the oil change. Clearly the filter is located in a relatively hard place to reach - but they removed the engine cover as well as the cover of the air intake handler to change the filter. Also, the oil filter is enclosed in some type of housing - so they had to remove and reinstall the housing after changing the oil filter inside the housing. Too many places for any little mistake that could have caused the P06DD code.
I have read the many discussions and posts on this forum regarding the P06DD code and the repairs performed to address the issue. Unfortunately, we do not have an oil gauge or oil pressure monitor on our dashboard - so cannot tell if we are experiencing low oil pressure. But thankfully the car is operating fine and we are not having any operational issues - like the limping engine issues and loss of engine power. We will go to the dealership to try to have the problem addressed - but don't want a never ending list of repairs when the light will not go off after replacing one component after the other. Of course, our extended Dodge 7 yr warranty just expired about a month ago in mid - May - what a pisser. Never even made one claim for the extra $1800 we paid for that plan.
So after reading all the discussions, we will ask the dealership to do the following to address the issue starting with the least expensive to the most costly. Please let me know if the following list needs to be revised or what else needs to be added.
1. Replace existing after market oil filter with Mopar brand
2. Check to ensure O ring in oil filter housing is secure and in place
3. Check and replace the Oil bypass value located under the oil filter in the the housing assembly
4. Check and replace Oil pressure sensor
5. Check and replace the Oil pump. This sounds very expensive. Is there any way for the dealership to check to see if the oil pump is not operating properly? Or is it only those stupid codes these days?
If we do all of these items and the CEL still does not go off, can we drive the car with the P06DD light on as long as we don't have any operational issues with the car??
Joyce
The Take 5 Oil change guys have been very nice each time that I have returned. Maybe I will just purchase a Mopar oil filter and ask them to replace the one they installed - checking for proper O ring position and the condition of the oil bypass value. Probably not, as they likely do not know what those parts even are.
Thanks for any comments or assistance.
Joyce
