1 - 4 of 4 Posts
Good evening everyone! I have a 2011 Town and Country and just this week I was I went to pull the door handle it went limp and pulled all the way back and didn't unlock the door.
However if roll down the window I can unlock the door from the outside with no issue. Is this being caused by a failed door lock actuator?
Thanks!
2008 Chrysler Grand Voyager Limited
That sounds like the rod from the handle to the mechanism has become detached.
it is possible the clip was not installed correctly at some point (previous repair perhaps) and it has just come off. Or the door handle it’s self has broken - I would suspect it’s unlikely to be the door lock mechanism it’s selfas they are pretty rugged - just the motors tend to fail
I forgot to reconnect mine whenI replaced the door lock mechanism I was able t refit it by feel with out disassembling everything- though it’s a lot easier if you can see what your doing.
1 - 4 of 4 Posts
