Status
Not open for further replies.
1 - 1 of 1 Posts
Discussion Starter · #1 · (Edited by Moderator)
Greetings. I've looked over quite a few posts about this issue, and haven't found one that mentions hearing the window trying to go up. My 2002 T&C driver window suddenly stopped moving. It was halfway down and pushing the switch up or down did nothing. I placed a bit of upward pressure on the window to no avail, but pushing down on it a bit and using the switch got it to go all the way down. Now it's stuck down inside the door. I can hear the motor working trying to raise it up with I press the switch, but the window stays stuck. I'm not very savvy when it comes to cars, but I can follow youtube videos and hopefully follow written directions to troubleshoot the issue and fix it. I thought my first step would be to ask here. Thanks in advance for any wisdom.
Not being sure if this is the correct location for this post, you will find the same question asked here: Driver Power Window Stopped Working
Moderator note: Please reply at the thread linked above.
1 - 1 of 1 Posts
Status
