1 - 14 of 14 Posts
Hi,
Some of you may remember me, I had the 2002 T & C with the leaking axle seal that many of you helped me learn to change. https://forum.chryslerminivan.net/threads/2002-transmission-can-it-be-saved.168169
Well that van finally gave it up (
56440
:cry:)
Well in May I bought a 2006 Caravan because I know it well and I like the van style vehicle (it's an extra vehicle, not our primary) . It has 171K miles with no problems. I've had it for 4 months now with no issues except for 1. Yes, the same issue. But it appears that the leak is around the axle seal holder and not from the axle seal itself. When I looked underneath during my pre-inspection buying, the seal holder had RTV sealant around the it. It did make wonder, but the van was only $2k and in very good shape otherwise.
It appears the previous person who did the job, did not put enough sealant around the seal holder before installing and then tried to seal the leak on the outside with RTV, but that has not worked. It is not leaking out of the axle seal, but from the interface of the differential and seal holder.
So, yes, I became an expert at taking the driver side axle out and replacing the seal (did it 4 times, but I could not get the leak to go away...there must have been something else going on).
But based on that experience, I'm a bit gun shy to tackle this in fear of making it worse. I'm on the fence of doing it my self or taking it into a shop.
If I do it my self, should I just redo the RTV or change the seal/axle once I'm in there. From the Carfax report, it says the CV joint was replaced in 2016 at 135K miles, I'm assuming that work was done then. The axle looks sort of new.
Thank you
I would change the seal and try one with out any rtv. I would also look at the seal's metal housing and see what color it is, on www.rockauto.com, national is red and SKF is blue, and would get the opposite of what is on it currently.
I would also suspect that who ever changed the seal last time damaged the bore on the trans housing and might need some more creative repair help like a gasket or an o-ring that fits the diameter of the seal lip that will compress between the trans housing and the lip of the seals outer diameter to eliminate the adhesion issue of the rtv.
Any pictures? Nothing to do with the boot clamp?
Discussion Starter #10 (Edited by Moderator)
Yes, Shellac will resist for sure.
Just make sure you use Indian Shellac:
Indian Shellac
Hi , I used Indian shellac (good stuff) but due to the location and low viscosity of the shellac, it won't stay (or build up thick enough) into the location I need it too. Is there any type of thick oil resistant sealant I could try?. The sealant needs to be somewhat resistant to oils (at least till it cures) as the fluid continues to come out (the attached photo is only after a couple minutes of wiping it clean). Attached is a photo using a UV flashlight I have (tranny fluid shows up with no special additives).
Thank you
56584
I meant use a paper gasket + shellac.
56586
Remove all those six bolts, separate that part.
Cut the gasket on the top part so you can insert it without removing the axle.
Apply shellac to both sides of the gasket.
Note:
I would apply shellac to the gasket a couple of days in advance, so it can dry and work better.
Good luck.
Discussion Starter #12
Understood, but I was trying to stop the leak w/o removing the axle since I'm a but gun-shy due to my previous issues with a leaking axle seal (which is not leaking now!!)
I don't think the two parts will separate very far if the axle is still there because the axle tripod will keep the seal holder from moving. If it does move, it would just be a very small amount. I would think getting the paper and shellac in would be difficult.
During my previous experience, when I removed the the seal holder, with the axle removed, it still took a lot of prying due to RTV sealant holding it together.
I contacted Permatex and they suggested this material. any experience with it?
Thank you,
Discussion Starter #13
Remove all those six bolts, separate that part.""
So I'm clear, separate the parts with the axle in or out. My goal was to try and stop this leak w/o removing the axle if possible.
If with the axle in place, you think it will separate enough with the tripod in place to get the paper and shellac in?
Thank you
Discussion Starter #14
Problem fix. Removed the axle seal holder and placed RTV sealant where it's suppose to be. When I removed the seal holder, there was no RTV, the previous person who did the repair did not put use any RTV, resulting in the leak.
1 - 14 of 14 Posts
