From the owners manual;
The automatic door locks can be enabled or disabled by performing the following procedure, Number one, close all doors and place the key in the ignition switch, cycle the ignition switch on/ off four times ending in the off position, do not start the engine. Within 10 seconds of the final cycle press the interior driver's door lock switch to the lock position, a single chime will sound to signify that you have successfully completed the programming. You can turn the feature back on by repeating the above mentioned procedure.
This did not help my problem but it's good to know.
There are several sensors that have to be closed for the doors to lock.
One of them being the key must not be in the ignition, The front doors must be closed etc, etc.
