1 - 4 of 4 Posts
02 T&C 3.3L flex fuel 41TE AUTO TRANSMISSION
02 T&C is weird the headlights dim while using them. Clock seems to gain time at a minute a day. Speedometer only lights up halfway and bounces when in park.Heater sometimes turns on with van. Sometimes at stop signs/red lights it jumps forward! Please help.
Recommend checking the usual suspects as contained in this thread:
And also verifying alternator performance:
Monitor alternator voltage while driving, which should be 13+ to 14+.
I see you're in the rust belt. Check ground connections for corrosion (there's a major one under the battery on the inside frame rail). Remove battery and flip up the "fuse box" and inspect all of the wiring plugs/connections underneath it. They get a little salt spray under there and corrode as well.
1 - 4 of 4 Posts
