1 - 3 of 3 Posts
So how many miles on the odometer? I am close to hitting 280,000 miles on a built in 2000 Grand Caravan ES. Just have done regular maintenance, like, air filter swaps, injector cleaner, rear bank valve cover gasket, pcv valve, Leak Detection pump valve replacement because plastic fuel tank would sort of "shrink," coil replacement, oil changes on tranny and engine+filter, oh, and a tranny replacement at 160,000 miles. Older transmission, according to a mechanic, had oil that was not the ATF+4 (bought vehicle with about 150,000 miles. Tranny only worked when set in reverse; in drive it would make grinding noises.
1995 Dodge Caravan SE 3.0 FWD "Wanda"
Sorry just saw this. Only 212k on the chassis, 122k on the engine.
1 - 3 of 3 Posts
