2014 Chrysler Town & Country 30th Anniversary Edition. 3.6L, 211kW
Hello.
Was wondering which sensor is which and where are they located at?
First sensor:
The info in description is a bit confusing. I know it’s located at the oil filter housing. Is it a coolant sensor or oil temp sensor? If coolant temp sensor then where is the oil temp sensor located at?
Second sensor:
Description is once again a bit confusing which fluid’s temperature it reads. And what’s the location of it?
Thanks!
First sensor:
Second sensor:
Thanks!
