1 - 8 of 8 Posts
I have been searching and searching for answers to this problem for months and cannot seem to get a good answer.
2006 Dodge Grand Caravan with about 145k miles on it. When backing out of our driveway (up a slight incline and turning to the right), I get a clicking/rattling sound from the front passenger side of the vehicle. I've taken it to parking lots forming tight turns in circles, but cannot seem to reproduce the noise, yet it has steadily gotten worse.
I have pulled the tire and inspected the suspension, but see nothing obvious (split CV boot, loose parts, grease), though I did replace a sway bar link that was split. I suspect that the CV axle shaft on that side is bad, but is it possible that it would only produce noise in that circumstance?
Thoughts? Advice? Any help is much appreciated!
a parking garage where you can drive up a few levels would be great for reproducing that sound. I have a squeak noise that happens only while on inclines as well. It's not the usual suspension sounds im familiar with and im starting to wonder if it's like a motor mount or a trans mount that's weak...
Double check the link you put on that it is still tight. The nut may have backed off a bit.
Unfortunately, the sound didn't go away after that repair. The link was definitely bad, but not the problem I was looking for.
Yeah, I have listened for it when I've entered places such as parking garages and don't hear it. Doesn't seem to be a wheel bearing or the like, but it definitely changes tempo with wheel speed.
Clicking is often associated with sway bar bushings or CV joints. May also be something to do with the brakes.
Making turns puts the struts into rotation, which in turn puts a twisting force on the sway bar connection, which translates back to the sway bar bushings.
Are the steel bands for the CV joint boots in good shape? They can rust out and open up, especially the large one..
Discussion Starter #7
They appeared to be. Going to take another look tomorrow. The very same van started missing last night from an apparent bad coil pack, so that's first on the list!
I have a 2001 T&C that made that noise but only in reverse while turning (like when coming out of my garage). This type of clicking noise under this circumstance is typical of a bad CV axle and that was the situation in my case. They are not that expensive to buy (about $100 or so) but you'll have to decide if you want to do the labor. It really isn't complicated but getting the axle nut off is difficult without air tools (on there with about 135 lbs of torque).
1 - 8 of 8 Posts
