Hi all! I've done some searching and haven't found any threads that address this issue specifically. My 1996 Grand Voyager with the 3.3L cranks for a very long time when starting cold. Warm starts are OK. Sounds like a fuel issue, right? So I hooked up the pressure gauge to the fuel rail, and turned the ignition on. 11 PSI. Hmmm. So I cycle it a few times, and only get 11-12 PSI. Crank it to start, and as usual, it takes about 20 or so seconds of cranking before it catches. The pressure climbs to 25-30 for a several seconds as it idles roughly, then the pressure goes up to 48 PSI. But it doesn't stay there, it fluctuates down to 45 and up to 48, back & forth. When I shut it off, it'll hold 45 PSI for well over an hour.
It runs fine, but it's a bear to start when cold, and I'm concerned that the fuel pump may be on it's way out. That, or the regulator, which is part of the pump.
What I'm really wondering, is what sends the signal to the pump to prime the system? I know when you turn the key on, the pump will run for a few seconds to build pressure. This isn't doing much pressure building. It's as if it's waiting for the signal from the crank position sensor before it energizes the pump long enough to build pressure. Could a clogged filter be causing this? It has 167,000 miles on it, and to the best of my knowledge has never been changed.
I appreciate any inputs or suggestions anyone might have. I'm a little lost here. It's not a simple case of the pump quitting outright or anything easy like that. Not that I want the pump to give up the ghost, but better now, in the driveway than out in the middle of nowhere, if you know what I mean.
