From: http://www.stevenashley.info/2008/01/coskatagm-backing-process-to-produce.html ...
The EcoGeek is reporting that GM and Coskata are readying a waste gasification/ethanol demonstration production plant at a GM manufacturing plant. The waste gasification plant will highlight GM and Coskata efforts to develop a process that will be able to produce ethanol at far lower costs that oil based gasoline production using a highly variable source of raw materials and contributing to a zero landfill waste production facility.
Coskata process does not use genetically modified organisms (GMOs) in this process, and because these bacteria are anaerobic, if accidentally they were released into the atmosphere, they would quickly die off because of the atmosphere's oxygen content. Coskata's research has been to identify suitable natural strains of bacteria that work well in their process and then selectively breed them to produce "thoroughbred" strains.
One of the grips the Green movement has against ethanol is that it normally takes 3 to 4 gallons of water to produce 1 gallon of ethanol. Coskata's process uses less than 1 gallon of water to produce 1 gallon of ethanol using 50% less energy and it doesn't need to use corn or any other food crops to do it with.
If this one holds up, I'll trade in my gas burners for ethanol burners tomorrow.
For more on the process check out EcoGeek article EcoGeek - Technology for the Environment
