Hard brake peddle
10K views 4 replies 4 participants last post by  tcwagner1
I would make sure you have a good vacuum source at the booster. I have seen problems with bad check valves and clogged ports in the past. Boosters are not a common failure. Siezed calipers can also cause a hard pedal.
