1 - 8 of 8 Posts
I have a 2014 Town & Country, U-Connect 430 - Satellite / Radio / CD / MP3 player with internal hard disk. Does anyone know what the storage capacity is for this hard disk?
40gb bare. But it's got system files and what-not on it. I forget how much is available. Enough for a ton of music.
Reactions: Jeepman and N8R
Reactions: N8R
Can you plug in a USB stick and play music off it? I have not tried that.
Then I wouldn't bother trying to upgrade the HDD. If you can get music through the USB port in the glovebox, you rarely even have to see it. Get a 512gb stick and have music for days straight.
A couple of sites that might interest you:
2014 Uconnect 430/430N Owner's Manual Supplement: http://www.fcacanada.ca/owners/en/manuals/2014/2014E-Uconnect-430_430N-Multimedia-3rd.pdf
Upgrade 430N Hard Drive, why haven't more done it?: https://www.wranglerforum.com/f40/upgrade-430n-hard-drive-why-havent-more-done-it-2354295.html
Starting at Page 89 in the above referenced Owner's Manual:
USB Port — If Equipped The USB Port in the center console or upper glove box (depending on the vehicle) gives you access to the audio files on the external iPod® or USB device through the 7 Uconnect® MULTIMEDIA (REMOTE DEVICES) 89 AUX Mode. It functions as a remote control for the currently connected audio devices mobile digital device, and you can play audio from the audio device through the vehicle’s speaker system. Before using the AUX mode, you will need to connect your audio device to the USB port. (See the iPod®/USB/ MP3 section in your vehicle’s Owner’s Manual on the DVD or the iPod® Control section in your User Guide for instructions.) NOTE: The files will not be stored on the internal hard disk drive and cannot be used in the HDD mode. NOTE: It is recommended you use the latest available software for your iPod® and iTunes. See the manufacturer’s website for updates: http:// www.apple.com/support/ipod/. Playing Audio Files From The Audio Device You can play songs directly from the iPod® or external USB device. Touch the TRACKS soft-key to display a list view.
With a thirty plus gig drive (can't imagine system files being more than a gig or so) you shouldn't have to worry about music storage. 1GB holds roughly 230 songs (at 128kbps). That's roughly 16 hours of music or 20 albums. So you should have room for around almost 9000 songs. Don't forget Stairway to Heaven!
1 - 8 of 8 Posts
