1 - 3 of 3 Posts
So been fighting issues with this van for a while nothing has worked tonight it started acting up again heat would go out real quick and trans would act like it was in neutral then back to everything being fine I have led headlight bulbs for over a year now and I had a random idea to turn the switch to on instead of auto and all the issues went away if you went back to auto the issues came right back
LED lights can mess up CANBUS signal stuff on some vehicles, never heard of it happening on these vans but i'd switch those out first and see if the issues persist
This vehicle is PCI Bus not CAN Bus but either way LED lamps can do weird things to the electronics. Swap them out for standard bulbs and see if your problems persist.
1 - 3 of 3 Posts
