1 - 3 of 3 Posts
Some of the heated seats in the R/T have stopped working. Giving the old come on and turn off soon after. I am wondering if someone can point me in the right direction for where the little control module will be located. Some searching has me confused. It looks like it could be behind the climate control but it also looks like it could be under the front seat(s). The van came with front and second row heated seats from the factory. Help is appreciated. Hope all are having a good weekend.
Pretty sure that symptom means failed elements.
Do your powered seats still move forward and backward? If not, there's a large fuse (40 amp I think) under the hood that blows, when wiring on the left edge of the driver's seat base gets damaged by the power seat mechanism. If that's your problem, there's a post on the forums that helped me fix mine, and I'll find it for you if you need it.
1 - 3 of 3 Posts
