My inlaws have a 2001 LXI (the loaded one.) It has automatic split climate control (driver, passenger and rear) Well we can't get any heat unless the settings are on "hi" and not a temperature and only out of the middle defroster opening. When it's on most any other position, there is always cold air coming out of the foot area.
Is this just the blend doors being stuck? Is there a sensor issue?
Also, this may/may not be related but the outside thermometer that's on the overhead cluster is way off. I guess it works in the summer but when we went up north and it was maybe 30-35 it said it was 110-120 outside. On the way home it was reading 60-80 when it was 20-25 outside.
It also has intermittent issues of the auto doors not shutting and the rear lift gate not unlocking.
Any help would be appreaciated.
