1 - 5 of 5 Posts
· Super Moderator
Ever experience Helmholtz Resonance with your vehicle? I have and it's not a pleasant experience. Likely not good for your vehicle's headliner either.
At highway speed, a front seat passenger opened the window and the effect on the Driver's side was a vibrating Wub, Wub, Wub. I remember experiencing that as a kid, and over the years, when somebody opened the rear windows.
Another Auto Design Fail: The Helicopter Effect, a.k.a. 'Side Window Buffeting,' a.k.a. Helmholtz Resonance
Explained: That Weird Throbbing When You Open One Car Window
You Can't Drive the Toyota Supra With the Windows Down
Reactions: LEVY
· Loveably weird
I don't drive with the windows down. That can really do a number on the headliner over time.
· --UNKNOWN MEMBER--
Hey Jeepman, you are risking to be called dumb, but then again, you might not just because you are a SUPER MODERATOR and you know how some of those guys are.
Agreed.
Saying it does is one of the dumbest things I have heard in a while.
Good luck! :oops:
By the way, I couldn't have said it better myself (Actually I could.....). :)
· Latent car nut
In my Acura if I crack open the two rear windows I get the resonance, however, if I then pop the sun roof into vent mode, the resonance is immediately remediated.
I think every car I've ever had could be coaxed into the good old whup-whup-whup, but oddly enough, I don't think any of our four vans have ever experienced the phenomena. Regarding the cars in which the resonance could be induced, I've found judicious use of sun/moon roof venting and differential openings of other windows could always eliminate the issue.
Reactions: Jeepman
· Registered
Caravan's have rear vent windows. Never an issue if they're open. Not much issue anyway until about 95mph (forgot to put the windows up before a drag).
1 - 5 of 5 Posts
