1 - 4 of 4 Posts
As t yet he title says getting that code constantly… replaced map sensor 3x but nothing. Then Spark plugs, Then replaced fuel injectors, it actually started and stayed running for ten mins. Went out for a drive but got stuck two miles from home. Luckily it finally started and we came right home. Changed fuel pump on Saturday same results. The only code is p0107. I have 2 videos of it running when their the mad sensor has lugged in running by featuring the throttle to keep it alive and another with it plugged in and not running. Can somebody please help!!!
Was just gonna say the injector wiring harness, particularly by the big black plug under the exhaust crossover pipe. Some of the other sensors' wires are run with it, which could be affecting it.
1 - 4 of 4 Posts
