1 - 4 of 4 Posts
Hello,
I have a 1996 T & C and recently have had battery problems (have to replace it). The battery died on us since we hadn't driven it in a week, so I attached a battery charger and everything worked fine except for the radio and clock. When I push the Time button, I am able to see the time for about 5~7 seconds before it automatically shuts off.
Has anyone else experienced or heard of this problem? I have tried looking for a solution online, but no luck.
5000 Club
First, if your battery won't last a week just sitting, it's time to replace it. Have you tried disconnecting the negative battery cable a few minutes?
20 year old enthusiast
Can't you remove the IDO fuse for a few minutes to reset the radio and such?
thank you very much, there was a problem with the radio fuse. I originally thought since the clock was able to turn on that the fuse was ok, and there would be some type of button combo to reset the digital display.
1 - 4 of 4 Posts
