1 - 3 of 3 Posts
2017 Chrysler Pacifica Limited fully loaded.
Help advise what to check. Our 2017 Pacifica Limited's head unit wont turn on. There is a button on the dash for "Screen Off" which we never touch. I've tried that button several times to toggle on/off, but nothing. Turned the van on and off several times and driven it too, and still nothing. Any suggestions what to check? Thanks
I'd start by looking for the fuse. If it's blown, there is probably a reason, so it might happen again.
Have you tried holding down the volume button and the time button at the same time? If you hold them down for a while it reboots the head unit. It’s like rebooting an iPhone. I just hold it down until I see the Chrysler logo. It’s probably about 30 seconds of holding the buttons down. When it’s done it turns off and then pushing the power button again turns it on.
I have to do it once in a while in my 21 to find the carplay. it might not do anything for you but worth a try.
1 - 3 of 3 Posts
