hey there. I have a 2003 Caravan that I'm having an issue with
168 Views 3 Replies 4 Participants Last post by  Turbo84
I have a 2003 Caravan that runs great, except when you kick it in passing gear. Then it completely cuts out, let off the gas some and it runs fine again. I changed the crank and cam position sensors because their codes were coming up, but I still have the problem. Any ideas?
1 - 4 of 4 Posts
Welcome aboard,
Assuming you don't get and diagnostic codes,
Did you check exhaust? could be plugged cat...
In addition to the clogged cat, what about fuel pressure? Had a vehicle that when you floored it, it would stall out as pressure was too low. Once the regulator was swapped, the problem went away.
Reactions: 1
1 - 4 of 4 Posts
