Hi all,
I would like to replace my HID lamps with regular Halogen lamp assembly.
After almost yearly replacements of the HID Bulbs now one of my ballast is not working. I did order and receive the new ballast but I am hesitant to install them. I will forever curse Chrysler for making these HID lamps so damn difficult to work on. No one should have to remove the bumper to access a wear part (ballast). One of the absolute worst design flaws with these vans IMO.
So, if I am going to remove the bumper, I would like to change out the lamp assemblies and go to regular halogen design and not have to ever take the bumper again (hopefully).
As far as I can tell, the halogen assembly is the exact same size and should bolt right up. ???
What I need to know, and am hoping one of you fine folks will know is; what do I need to do to make the plugs work? I am thinking there will be some cutting and splicing involved.?? Part #'s or links for the plug would be wonderful. Will the other lights (side marker/ DRL-high beam) attach to the new lamp assembly the same way as existing? Any concerns with the voltage change?
Thank you!
Thank you!
