This is a 2010 Dodge Grand Caravan
If I turn the high beams on, the blue light turns on above the instrument panel like the high beams are on, but all that actually happens is a brief flash of bright light from both high beams, and then it goes back to just low beams. The blue high beam light stays on until I move the lever back to the low beam setting, and then the high beams flash one more time and the high beam light goes out.
If I pull it back for "flash to pass", the low beams come on if the headlights are off, or it gives a very brief high beam flash and shuts back off if the low beams are already on.
Is there a circuit breaker somewhere that needs replaced? I couldn't find one in the manual
