Having a driveability issue.
I fueled $40 in the tank yesterday on way to jobsite. The fuel tanker was dropping off when I was there.
I hope they didn't put E-85 into the reg unleaded tank/pump by mistake. I made it to my destination, normal... about three miles. Then a trip to home depot and back (an additional 28 miles roundtrip) ,
Then on the way home from the worksite, stumble and stall. Seemed to be OK while driving on but rolling though an occasional stumble or hesitation may have been detected. Stalled at lights. Aarg I do remember thinking just prior that the fuel pump seemed loud??
If I shut off the engine and restarted it ran ok until a pause or interruption.
Thinking my Delphi fuel pump replacement less than five years ago (I can hear it running) Have to get fuel pressure test gauge set from AutoZone. Will also take a fuel sample and do the water test for alcohol content.
OR
Years ago around the same time frame, but after the fuel pump, finding that it ran great but then would do similar after spirited driving or hot day. I found with the forums help that if I kept a bottle or pail of water and used it to cool the ignition coil it would start right up and run great until heated again. I installed a heat shield above the crossover pipe after as I felt the pipes heat was soaking the ignition coil and I hadn't had any further issue since then.
I've not even popped the hood yet, I was beat after working in the field all day.
When I first bought the van and joined the forum, I did inspect and take precautions regarding the injector wiring. Perhaps that too...
Was running great and then I put that gas in.... the only thing that changed BUT I did get quite a few miles before failure.
Habia una vez...
I've been studying Spanish on DuoLingo app for free!
OR
Habia una vez...
