Hey guys,
This is driving me nuts trying to figure this out. I want to blame this on the new sway bar end links I installed last February 2022 with proper torque. They worked great. However, I just recently re-torqued end links thinking that would solve issue(I discovered they were way under torque after a susp. shop did springs/ stuts/rods in March.) I don't see how it could be them after inspecting them again. (See below)
**I had my dad shake the front corners of the van while I listened and saw, heard, felt, nothing from sway bar links. Today, I put front end on ramps crawled underneath and shook the sway bar as hard as I can where it connects to links. There is no play between bar and links at all. Nothing ? The sway bar has no indications of rubbing metal down the whole length and those inner bushings look great too.
Other things I have checked and ruled out:
1. No movement side/side or top/bottom with wheels off the ground. Or while turning steering wheel (Tie Rods, Bearings/hub, ball joint all good)
2. No cv issue I think. (No clicking while turning hard left or right forward or reverse or at highway speeds)
3. I inspected suspension cradle plate religiously looking for anything loose or rubbing. Everything great and the frame isolaters all in excellent condition and tight.
4. See no play/movement in new strut towers when I shake them with Van on jack stands.
Symptoms:
1. Clicking noise on initial start in both forward and reverse usually only on small inclines at like a stop light. Or "particularly" on our uneven gravel driveway on the farm.
2. It goes away completely after one or two clicks and do not usually hear anything although I think I have noticed it again at medium speeds when one side of van dips down on these country roads.
3. Sometimes after initial start up when VAn is cold I will hear it when van shifts from 1st to 2nd. Not usually.
4. I always hear it most when I park on the farm. I park on an uneven gravel driveway, nose pointed slightly downhill. When I put shifter in park and take foot of the brake. It will roll forward slightly and that is when I hear the click the most.
Like I said, I want to blame the end links from what I have read but they don't seem bad unless I am testing them wrong.
Van runs and drives excellent, passed stringent NY safety inspection no problem. I have to take a trip NY to Tennessee the middle of August and would rather figure this out.
What am I missing here?
With much gratitude,
Luke
Symptoms:
Luke
