1 - 1 of 1 Posts
Just thought I would post some information on the $40.00 Micro Mini Fuel pump I put on my 82 Dodge Truck because of the gas evaporating from the carb bowl while sitting for weeks at a time. I installed mine as directed near the gas tank but on the passengers side frame rail. It works like it should pushing fuel up through the mechanical pump at the front. I installed a shut off switch as I only need it for a primer. I does not have an auto shut off feature and will run constant at 6lbs. pressure. I was a little discouraged about that but then it is not allowed to run for more than a minute or so. It has solved my dry carb condition so I do not have to take the breather off and pour gas into the carb any more. :thumb:
1 - 1 of 1 Posts
