1 - 2 of 2 Posts
Need PCM pin diagram, i.e., pin (cav) number, color wire and function for 1996 T&C
If anyone has a link to or diagram of 1996 T&C PCM pins, it would be greatly appreciated.
Can't find one for 1996 - 2000. 2001 and after are different, at least as far a wire colors best I can tell.
Thanks in advance.
Discussion Starter #2
If someone has a need as I did:
CAV CIRCUIT FUNCTION
1
2 K18 18RD/YL Ignition Coil No 3 Driver
3 K17 18DB/TN Ignition Coil No 2 Driver
4 K20 18DG Generator Field Driver (+)
5 V32 18YL/RD Speed Control On/Off Switch Sense
6 A142 18DG/OR Automatic Shut Down Relay Output
7 K13 18YL/WT Fuel Injector No 3 Driver
8 K20 18DEG Generator Field Driver (+)
8 K90 18TN Smart Start Relay Control
9
10 Z12 18BK/TN Ground
11 K19 18GY/RD Ignition Coil No 1 Driver
12
13 K11 18WT/DB Fuel Injector No 1 Driver
14 K58 18BR/DB Fuel Injector No 6 Driver
15 K38 18GY Fuel Injector No 5 Driver
16 K14 18LB/BR Fuel Injector No 4 Driver
17 K12 18TN/WT Fuel Injector No 2 Driver
18
19
20 F87 18WT/BK Fused Ignition Switch Output (ST-RUN)
21
22 G3 18BK/PK Service Engine Soon Indicator Driver
23
24
25 K42 18DB/LG Knock Sensor Signal
26 K2 18TN/BK Engine Coolant Temperature Sensor Signal
27 K127 18BK/OR Oxygen Sensor Ground
28
29
30 K41 18BK/DG Oxygen Sensor 1/1 Signal
31 K90 18TN Smart Start Relay Control EXCEPT: 3.0L
32 K24 18GY/BK Crankshaft Position Sensor Signal
33 K44 18TN/YL Camshaft Position Sensor Signal
34
35 K22 18OR/DB Throttle Position Sensor Signal
36 K1 18DG/RD Manifold Absolute Pressure Sensor Signal
37 K21 18BK/RD Intake Air Temperature Signal NOTE: 2.4L
38 C103 18DG/LB A/C Swith Signal NOTE: Except 3.0L
39
40 K35 18GY/YL EGR Solenoid Control
41 V37 RD/LG Speed Control Swith Signal
42 C18 DB A/C Pressure Switch Sense
43 K4 BK/LB Sensor Ground
44 K7 OR 8-Volt Supply
45 K103 DB A/C Switch Sense
46 A14 RD/WT Fused B(+)
48 K40 BR/WT Idle Air Control Motor #1 Driver
49 K60 YL/BK Idle Air Control Motor #2 Driver
50 Z12 BK/TN Ground
51 K141 TN/WT Downstream Oxygen Sensor Signal
52
53
54
55
56
57 K39 GY/RD Idle Air Control Motor #3 Driver
58 K59 VT/BK Idle Air Control Motor #4 Driver
59 D1 VT/BR CCD Bus (+)
60 D2 WT/BK CCD Bus (-)
61 K6 VT/WT 5-Volt Supply
62 K29 WT/PK Brake Switch Sense
63 T10 YL/DG Torque Management Request Sense (EATX)
64 C13 DB/OR A/C Comp Clutch Relay Control
65 D21 PK SCI Transmit
66 G7 WT/OR Vehicle Speed Sensor Signal
67 K51 DB/YL Auto Shutdown Relay Control
68 K52 PK/BK Evaporative Emission Solenoid Control
69
70
71
72 K107 YL/BK Leak Detection Pump Switch Sense
73 K173 LG/DG Rad Fan Relay Control
74 K31 BR Fuel Pump Relay Control
75 D20 LG SCI Receive
76 T41 BK/WT P/N Position Switch Sense (EATX)
77 K106 WT/DG Leak Detection Pump Solenoid Control
78 V36 TN/RD SC Vacuum Solenoid Control
79
80 V35 LG/RD SC Vent Solenoid Control
1 - 2 of 2 Posts
