Friends, I'm desperate, I can't figure this out.
I have a 2010 T&C Limited with 4.0L and 3-zone ATC.
The car has little to no heat.
What I have done so far:
1) Topped off coolant, it's full
2) Replaced thermostat, original was fine.
3) Replaced cabin air filter (was very dirty). No difference.
4) Pulled apart dash and checked all blend door servos; all working.
5) Held the AUTO/SYNC button on the ATC to calibrate doors, no errors I can hear all front and rear servos cycle.
6) Pulled lines to heater core and reverse flushed them, some minor junk came out (coolant does have rusty color). Core runs freely. Inlet gets very hot, outlet still stays cold.
None of this has worked, still have no heat.
At idle, van blows cold air.
Revving the engine produces some heat, barely.
Driver's side in center console upper vents is warmish, passenger side is cold, never gets warm even on engine rev.
I have noticed that the A/C compressor clutch cycles on and off while idling - that's odd since it's 20 degrees outside here.
Bottom line, I'm out of ideas, and it's very cold here in the Northeast.
Any ideas? There is so little information on troubleshooting 4.0L vans. I've been all over many forums and YouTube with no luck.
Thank you!
Thank you!
