Just finished installing a new tstat (though I knew it probably wouldn't make a difference), removed driver and passenger acuator to confirm they were working and also manually adjusted the blend doors...all working fine. Absolutely no heat in the back but fan working fine. About to burn it lol.Same situation here. 2010 4.0 Town &. Country no heat at idle front or back, heat while driving. In new england in dead of winter. Outlet hoses from front and back cores are cold to the touch while at idle. Will plan to flush both but seems weird that they would both clog at the same time. Were you able to figure it out? Am planning to start with an entire cooling system flush.
Hi I have talked to a Chrysler mechanic and he said the oil cooler has been a problem try bypassing it mine is doing the same thing going to check out the cooler 😊Friends, I'm desperate, I can't figure this out.
I have a 2010 T&C Limited with 4.0L and 3-zone ATC.
The car has little to no heat.
What I have done so far:
1) Topped off coolant, it's full
2) Replaced thermostat, original was fine.
3) Replaced cabin air filter (was very dirty). No difference.
4) Pulled apart dash and checked all blend door servos; all working.
5) Held the AUTO/SYNC button on the ATC to calibrate doors, no errors I can hear all front and rear servos cycle.
6) Pulled lines to heater core and reverse flushed them, some minor junk came out (coolant does have rusty color). Core runs freely. Inlet gets very hot, outlet still stays cold.
None of this has worked, still have no heat.
At idle, van blows cold air.
Revving the engine produces some heat, barely.
Driver's side in center console upper vents is warmish, passenger side is cold, never gets warm even on engine rev.
I have noticed that the A/C compressor clutch cycles on and off while idling - that's odd since it's 20 degrees outside here.
Bottom line, I'm out of ideas, and it's very cold here in the Northeast.
Any ideas? There is so little information on troubleshooting 4.0L vans. I've been all over many forums and YouTube with no luck.
Thank you!
I had all the same symptoms...it took reverse flushing WITH COMPRESSED AIR several times and 45 mins of idling with one of these funnels but now I have heatWhat does an oil cooler have to do with the HVAC system?
Hi, did you ever fix the rear heating issue?I had all the same symptoms...it took reverse flushing WITH COMPRESSED AIR several times and 45 mins of idling with one of these funnels but now I have heat
Hi,Friends, I'm desperate, I can't figure this out.
Thank you!
Hi,
Did you end up fixing the rear heating problem?
