Guys - I may have found the solution. I've tried everything you all tried above except the water pump on my 2010 GC with 4.0L. Try bypassing the oil cooler (may be specific to 4.0L) and see if you get heat or at least hot return lines from the heater cores.
My initial symptoms in January
My repairs in January / February
Fast forward to September
- No rear heat
- Partial front heat
- New front core without draining coolant ... no change in heat output
- Drain coolant, new rear core, flush rear lines, new front hoses with aluminum y-fittings, prefill rear core and lines, new thermostat, refill radiator with new coolant, bleed system
- Front heat is hot, rear lines are cold at idle but rear heat works at 2000 rpm and above.
- Take van to repair shop for water pump and timing kit swap and mention all of the above on why I want the water pump.
- Repair shop finds a small leak at the plastic thermostat housing and says cooling system won't hold pressure.
- They convince me to go with a new thermostat housing and they will flush the cooling / heater system with water, air, and a cleaner before the timing and water pump job.
- They find the "new" heater cores are plugged again, the lines going to the rear were partially plugged, the radiator had a lot of build up. All of these they are flushing separately.
- They also find the oil cooler is completely blocked and they can't clear it. They bypassed this and coolant can freely flow to the cores now.
