1 - 3 of 3 Posts
Hey all, I'm new to the forum, and I'm having some trouble with my 05 pacifica base model. The engine was rebuilt, and ran fine when put back together, but one day I drove to Walmart, and it no longer started. The "run relay" clicks once, but the ignition relay nor fuel pump kick on. Upon testing the starter qt the relay, it cranks, but there's no spark or fuel. Any body that can tell me if there's a main ignition system power connector that I could check? I'm still diagnosing where the problem would be, but I fix bikes not really cars. Any and all help is greatly appreciated.
Welcome,
What is "run relay"? is this the ASD (automatic shut down) relay?
ASD should be your first suspect, and not only that it clicks, but that it actually energizes fuel and spark circuits.
The relay and fuse box "IPM" is also prone to corrosion and should be checked that connectors underneath are getting power.
Pacifica should also have Immobilizer, make sure that it's not preventing it from starting (no red light on dash).
1 - 3 of 3 Posts
