I have a 98 Plymouth Grand Voyager "Expresso". I've been having issues, I replaced the BCM and the radiator quit working. I replaced the relay for that, no good so I direct wired it off the battery to a switch and everything seemed good for awhile. The other day I was idling down the street and it just died, no warning just died. It would turn over but not start. It sat for about 12 hours and started right up, ran for a bit than died again. Sat for another 12 hours and started right up again.
I was wondering about fuel so I put a pressure gauge on the fuel rail and with the engine idling the gauge rapidly oscillates between 50-65 pounds. I let it run for about a half hour, shut it off and it won't start again. I put a plug tester inline in the plug wire and it shows no spark.
Just wondering if anyone has come across this before or has any thoughts on why it will start, run and than lose spark and quit running after a period of time.
