We've been having a problem with our 98 Voyager intermittently not starting. I've been reading posts on the problem and a few sound like a similar problem.
At first I thought it might be low battery, bad positive post connection. Cleaned and reseated terminals. Everything seems to come on. The headlites are bright, radio, etc. I'm not getting any chatter from the relays either. All I hear is a click from one of the relays under the dash. The owners manual doesn't identify those relays. Also checked the Starter fuse in the #12 spot and and traded all the relays in the unit under the hood that looked like they might have anything to do with it. My big dread is that it might be something in the ECM, but none of the posts even mention that. Is there anything in the ECM that would shut down the starter? How do I go about checking the ignition switch. Is it a good bet that, in fact, the starter may be on the fritz? Where should I start troubleshooting? I do have a voltmeter but no diagrams to guide me. Any suggestions welcome.
Al
Al
