It is a 2007 Dodge Grand Caravan with 226,000 miles on it. I replaced the oil pressure sending unit with a new MOPAR unit. The light still comes on at idle and goes out when the vehicle accelerates.
I assume the next step is to pull the sensor and attach an oil pressure gauge. What readings should I see?
Has anyone had these symptoms, and if you resolved the problem, how did you do it? I have been pretty consistent with maintenance including oil and filter changes. Not sure if this is an indicator that the engine is not long for this world.
