1 - 4 of 4 Posts
Probably a little more than an oil change...unless you're down 4+ quarts. The oil pressure warning light (with chime) should only come on when oil pressure drops below 4 psi, so something else is amiss.
The oil pressure switch could be failing; it's mounted to the oil filter adapter. Mopar part number 4608303AB. While I wouldn't use aftermarket Chinese stuff, these are widely available at almost any parts store for under 15 bucks.
Font Number Rectangle Document Publication
Auto part Gas Household hardware Technology Metal
That said, you could have internal problems, such as a failing oil pump, a badly clogged/obstructed filter, or something else. To truly assess pressure you'd need to screw in a mechanical gauge and observe throughout the RPM and temperature spectra.
I'd probably inspect and replace the switch first and go from there. It's right up front (see #5 below). You will need a special socket to R&R the switch, but the parts store should have a loaner. Best of luck.
Motor vehicle Mode of transport Font Auto part Diagram
1 - 4 of 4 Posts
