1 - 20 of 27 Posts
· Registered
A while i posted about that the passeger side mirror does not move with memory or tilt down when in reverse. Well i have had my car in for service for oil change and other things, and the tech and service writer were working on this isssue for over two days and did not make sense to them and they could not find any problems. The service dept. had several dicussions with chrysler and then chrysler informed them that when you have the memory package, the passenger side mirror does not tilt or move with the memory. This makes no sense to me or the dealer but thats what chyrsler told them.
If possible i would appreciate if any one with limiteds or other 08's with memory seats, when you put the van in reverse do both the drivers side and passenger side mirror tilt down and if you move the mirros then press the memory does the passenger side return to its position.
thank you in advance.
· Banned
You can select the mirror to tilt down when in reverse on PERSONAL SETTINGS (CUSTOMER
PROGRAMMABLE FEATURES)
You can set this feature to on or off using the left button on the steering wheel.
* If you can program the left mirror with memory you could also do that with the right mirror.
· Registered
Discussion Starter · #4 ·
Both should tilt with the backup assist...Mine do...
When I picked up the van, after the service advisor and mechanic taking apart the door and van to fix this for two days, replacing the mirror, checking the software, checking the electic system and after several calls with chyrsler and going through the build and diagnostic database on these vans they found diagnostic and build paperwork from chyrsler, which they showed to me, that indicated that both mirrors do tilt in reverse so long as you do not have memory seats. If you have memory seats only the driver side mirror is connected to the memory and the passenger side isn't and does not tilt. This made no sense to me or the service department why chrysler would do this. But according to chyrsler the van was purposely programed this way. I am the first to bring this up to the service department and they are now exepcting a lot of people who have memory seats are probably going to complain.
Please confirm if you have the memory option????
· Registered
Discussion Starter · #7 ·
Well, I called my salesman and asked if they had a limited in the showroom, they didn't but my saleman brought one from the other lot. He said he would check it out but i said i want to come down and make sure the memory works and the tilt setting is enable. I went by early this evening and it was an 08 limited BB with only trailer option package and DVD players, identical to mine down to the biege interior, except i don't have the DVD.
Lo and behold to my salesman's and my surprise, the memory function and tilt on reverse does not work on the passenger side, but works only on the driver's side. I called service and they had a red limited in there lot and same thing. I just don't get it and neither do the saleman and service. The only way I can described it that chrysler is F***ing stupid.
· Registered
Passenger Side Mirror
I have a 2008 T&C Limited and have the same problem. The driver's side mirror turns down in reverse but the passenger side does not. It is not possible that they did this on purpose, it is just too stupid. Someone screwed up the software.
· Registered
Discussion Starter · #11 ·
Please read through all the posts.
Chrysler did this on purpose, I have tested three other limiteds including mine and people on other forums are saying the same thing. Also I posted previously, the tech and service mananger each showed me documentation from Chrysler showing this was done on purpose.
There is an option in the PERSONAL SETTINGS (CUSTOMER
PROGRAMMABLE FEATURES) to set to on the passenger mirror down.
Have you check this option.
If the driver mirror is tilting, the setting is enabled, there is no way to make the passeger side work (without some update from Chysrsler in the future). Also, you will notice that the passenger side mirror is not connected to the memory function.
· Registered
The funny thing is that if they were only going to do one, the passenger side probably made more sense than the driver side. After all, the passenger side lowering can be helpful with parallel parking. When you are backing up on a street to exit a parking space however, having the drivers side mirror not lower helps you to pay attention to traffic that you intend to pull out in.
· Registered
ok wait a minute you are telling me that the 08 touring has this option? I have the chrome power dimming mirrors but neither of mine do the tilt down feature and did not see anything in the EVIC about it, hmmm now I am wondering whats up with mine...
· Registered
whats more is I just looked and there is nothing in the service manuals about the tilt feature within the EVIC does not even list it as something that is an option... HMMMMM
· I DON'T live in an Igloo!
So has anyone been able to figure out just why the drivers mirror tilts (uselessly) and NOT the passenger? I know mine is exactly that.
· Registered
Discussion Starter · #20 ·
Just to clarify the
Limited (at least in the USA) comes standard with memory driver seat and only memory driver side mirror. Only when enabled (which i shut off) only the Driver's side mirror tilts in reverse. As of the 2008 models, the passenger side mirror is not connected to memory and does not tilt in reverse.
The Touring, as it is my understanding (I do not own one, so I am not 100% sure) both mirrors tilt when you have the reverse sensors. I have an 08 touring loaner without reverse sensors and I will check that later.
The reasoning that the passenger side mirror in the Limited's are not in memory or tilt, I know of none.
1 - 20 of 27 Posts
