P0720 Output Speed Sensor
153 views 13 replies 4 participants last post by  Superbee
#1 ·
Engine light got P0720 Output Speed Sensor, coming to stop (only when stopped) in gear Speedo goes upto 20mph i can fill the van shifting gears at a stop, i replaced the sensor still does the same thing? any ideas
#6 ·
Yes it is an AWD, I have not checked The axle that didn't even cross my mind never heard of that, BUT i will go check it, Now the Alternator i did have this happen back in 2019 speedo was jumping going crazy until it popped itself had to do a reset to make it work again took it to tranny shop he said that i bulletin just came out about the diodes in the alternator can cause that changed alternator fixed it bad thing about getting a lifetime alternator from advance auto is NOW they will not honor a lifetime they say wear and tear no warranty, BUT will get it checked
#7 ·
Speed sensor and TONE wheel hub.
owns 2006 DODGE GRAND CARAVAN SXE
#8 ·
#9 ·
TONE wheel is important.
#14 ·
ok Went to 4 different Advance Auto Store to try to get warranty on the Alternator NOT one would warranty it so FYI on (Advance)
I changed the Alternator and that has fixed the problem
Thanks Guys
  • Wow
Reactions: Mopar-Mofun
