1 - 2 of 2 Posts
Hello everyone!
I have a 3.6 L 2013 Chrysler Town and Country.
It had an occassional hesitation that never tripped any codes. Recently however he engine idle got worse and he van shakes when accelerating. I ran low on fuel and it got way worse.
At first P0302 cylinder 2 misfire was the only code so I swapped out the coil pack and spark plug, but the symptoms only got worse. Now I have a whole slew of codes as per the thread title and I can hear a rhythmic knock or clink in the engine bay. Codes indicate cylinder 2 and 3 misfire, multiple cylinder misfire (obviously) and Bank 1 Air - Fuel Ratio Imbalance.
I have followed a few threads here but I have not been able to resolve the issue.
I did find a bunch of oil build up outside the PCV valve but after popping it off the valve was clean and working properly.
Any ideas?
2014 Town & Country
I had a P0303 on my 2014 3.6L. It ended up being a rocker arm problem...which evolved into it eating into one of the lobes on the exhaust cam.
A rhythmic clicking sure sounds “no pun intended” like mine did.
It’s a known issue for the 3.6’s.
I diagnosed mine with a mechanic’s stethoscope. I could clearly hear a noisier, anomalous rhythmic ticking sound when I put the stethoscope near Cylinder #3 when compared to the other six cylinders.
1 - 2 of 2 Posts
