If you're looking for keeping the temp down, you could finish it off with this stuff. It definitely works for keeping things a little cooler under a metal roof
Black Jack® Silver-Seal 300
Hopefully the white will be adequate. The blue absorbs so much heat it's scalding to touch even on a cloudy day.If you're looking for keeping the temp down, you could finish it off with this stuff. It definitely works for keeping things a little cooler under a metal roof
The silver stuff will make a difference, but I don't know if it's worth the extra 20 bucks.Hopefully the white will be adequate.
