Subscribed.
Same problem on driver's side for me. The power door stopped working, as well as the power window on the sliding door. The power window and door don't work from the control on the sliding door or from the driver's seat controls. But the power door lock does still work on the otherwise inoperative power door/window though. I assume it is likely a broken wire in the wiring harness underneath the door in the tank-tread looking black plastic cover, so I plan to start there. But not sure if fuses or bad relays are common problems on these as well, or some other likely cause. Will look for grounding issues as well. Thanks.
