1 - 16 of 16 Posts
· Registered
Bought new in 2008, built on a Monday. When we got it, the steering wheel was just off of level, and I am sure that they tweaked it ever so slightly. Front tires had significant wear on the edges at 12,000 miles. Actually, by 12,600 miles I was concerned enough to ask about alignment and the dealer said that was out of warranty at 12,000 miles.:angrya: I bought a 5 year alignment from NTB, and had them align it. At about 20,000, new tires up front.
I don't rotate tires, as my opinion is it just smears the evidence and makes four wear out in twice the time it would take two. There is significant wear after 10,000 miles. I finally figured out that the NTB guys sucked, after I got it aligned at one shop, then drove it to another the next day and had it checked, the paperwork may as well have been for two different cars.
I finally paid Chrysler and they had some old guy who said he was the god of alignments and that he would get it done right. He said that the struts were bent and that would have to wallow out the holes in the struts to get it to 0° Camber, and that the specs are so broad from Chrysler that having it "in spec" means nothing. He said that aftermarket struts are slotted for adjustment, but that the factory pieces are not. This was around 50,000 miles.
No real improvement. My tires last 20,000 miles whether they are the best ones, or the crappy ones. Now, I am at 129,000 miles and have nearly shredded another set of Michelins. The outer edges wear badly.
Recently, I get real bad brake stutter when braking, it shakes the steering wheel. So.. I am planning on new pads and rotors, and maybe the Gabriel easy strut pieces that rock auto has with the spring coil included as an assembly.... Wondering how much more of a job it is, if I am already doing the brake rotor to do the strut too. ? I have done struts on four or five cars in the past, just wondering if this van is unusually easy or hard in some regard. ???
Does anyone else have such horrendous tire wear ? I get 20,000 miles ?? Its getting real old.:angry:
· Premium Member
I'm over 50K on my 2013's factory tires and there is more than half the tread left.
I rotate every 10K or so and run 38 PSI.
Chrysler stopped offering factory camber adjustment (slotted struts) 20 years ago started with the 3rd gen in 1996.
Struts are relatively easy to do on these vans. The only sticking point will be getting the swaybar links off the struts if they are old and rusty. It may be easier to cut them off and replace them as well.
Do you drive it hard?
· Registered
By 10,000 miles, my tread is trashed on the outside edges. Its really not good in the center either. For about 10,000 miles on one set, I maintained above 40 psi and it made NO difference. It would be nice to be able to adjust the TPMS to alert at 38 instead of 32 psi...
I don't really drive the van too much, its my wife's and I always drive when I am in the car. I have lectured about hard cornering, but I don't know for sure how she drives when I am not there. Mainly low speed subdivision driving, but that may be the most hard on the tire edges.
I live in Houston, TX. No real rust to speak of under the cars here. I remember the sway bar end links from my 98 GV. A pain, but it was just because 3 hands would have made the job much easier.
· Registered
Proper alignment - regular rotations - proper air pressure - "normal" driving conditions = good tire life.
Start changing the above parameters and tire life diminishes.
· Super Moderator
Air pressure has to be "cold" air pressure, not heated up by driving, sun or ambient temperature rise of the day.
Some tires don't wear well.
All the talk in a Post above about the struts being bent sounds like "talk", nothing else. Camber stays real, real good with the OE struts, in my experience with two 4th Generations.
· Premium Member
These are the specs I found for a 2008:
CAMBER - LEFT −0.10° ACCEPTABLE RANGE −0.50° to +0.75°
CAMBER - RIGHT −0.40° ACCEPTABLE RANGE−0.80° to +0.45°
TOTAL TOE +0.26° ACCEPTABLE RANGE +0.06° to +0.46°
If that alignment "guru" truly set your camber to 0° he didn't do you any favors.
· Registered
Discussion Starter · #7 ·
Yes, I wish that I could get real good info on the alignment. At NTB, a guy would do the alignment and hand me a printout, showing me that it was within "specs." I literally drove it to another NTB shop a few miles away a day later and expected to be handed a very similar printout. It was not just vaguely off a tenth of a degree, but nothing matched. Almost like the guy fetched some old crap out of the trash and handed it to me. Except I watched both these guys do their thing, and then hit print. Disappointing. Non-repeatable results, which taught me that going there was a waste of time.
I had a similar issue on my old '98 Caravan, except in that case, the guy could show me how the computer read "on target," but he could roll the van back a foot and then forward to the same spot (on the lift) and see the reading was well off. He found that the tie rod end was bad and that until it was fixed, it couldn't maintain the alignment. I was hoping for a "smoking gun" here. There have been none, so far. Except my wife's driving and maybe not keeping the pressure above 40psi.
· Registered
What brand and model tires are you using? Some tires like the OEM Yokohama Avids were terrible after the first year, countless cases on this forum about longevity, ride quality, traction and a laundry list of other things.
Does your van pull to either side when driving?
· Premium Member
See the OP's first post
· Super Moderator
This is what happens to the tires, way faster than it seems like it should. Nearly equivalent wear on the inside edge too.
WOW, I think you need a new air pressure gauge if you are using 38+ psi cold.
· Premium Member
· 3rd gen > all others
Thank you for posting your location, as that helps a lot. I'd say it's because you live in the southern hotter states that you don't get better mileage from your tires. The hotter temperatures and much hotter road surfaces down there decrease the life of ALL tires. I've read tire reviews on tire rack for the same exact tire AND vehicle and have seen very different tire lifespans, with the only variable being region they are used in. Some people say a tire gets the full rated mileage (usually a northern state or country) and others say the same tire on the same vehicle wore out in a third of the mileage and that they're terrible tires (always a southern state), which led me to the correlation of tire wear vs. geographical region.
· Registered
Discussion Starter · #15 ·
Some updates:
I have changed a bunch of things: Bought some used 17" rims, changed the rotors, calipers, pads, and tires. I bought new cheapo tires for the rear at NTB (I actually like them a lot, the tires that is.) And put two of the used ones (that were the best two of the four when I got the 17" factory rims) on the front. Basically, I did a big brake upgrade and had to change wheels. Lets see how that works....Well, the two tires that were Fair/good are wearing like the last bunch, i.e. wearing quickly.
I took it to a guy who was of Legendary status at a Firestone in Houston and waited 3 hours while they checked out my car. He said that there is nothing wrong, but that it may need an alignment. I gave him one very important clue, to me anyways. "About one out of every 20 stops, the brakes have a hefty shudder that pulls at the steering wheel, pretty severely. Not every time, maybe just one out of 20 times, more often when braking while on a turn...." He had an assistant drive the van slowly forward and backwards at low speed and then jam on the brakes. You could see the wheel move forward/back in the fender opening when he jammed on the brakes. He pronounced it bad control arms. Finally an answer. His sky-high estimate of $1,600 for the control arm replacement gave me pause, tho. I bought some new control arms online and changed them this weekend, took about 3-4 hours. $300/hr, not bad wages. The van drives beautifully, but on one stop, the steering wheel shook a bit.... This is about unchanged, unfortunately. The worse of the two front tires also was showing a tiny bit of cord, so I am off to get two more tires for the front. I didn't want to replace the tires until I had new control arms on it, in case that fixed it. Looks like I would have wasted the $1,600 if I had paid it.
So, I am running out of suspects. I guess I could look hard at the tie-rod ends, and inners, the rack, and maybe the rack mounts. Struts are original and now have 140,500 miles. They function just fine, don't leak, and control bounce like they should.
· Registered
Some updates:
Maybe someone needs to drive beside you on the hwy and observe all four of the wheels when you brake to see if they vibrate or not.
1 - 16 of 16 Posts
